My friend faced similar kind of issue last one month, he can try lots of verify but no result, he was still searching for some proper solution. need help…](https://www.wellcaremedicare.net/)
The encapsulation of Python is relatively easy, which involves reading and writing two actions, then initializing the registers according to the manual and writing screen data. The encapsulation of Python is relatively easy, which involves reading and writing two actions, then initializing the registers according to the manual and writing screen data.
Hello,Look for Arduino libraries: Check if there are any Arduino libraries available for your specific display model. Many popular displays have Arduino libraries that provide ready-to-use functions and examples for interfacing with the display.
Adapt existing code: If there are Python libraries available for your display, you can try to adapt or port the code to Arduino’s programming language (C/C++). Python and Arduino code can differ, but with some modifications, you may be able to make the necessary adjustments and utilize the existing driver code.
Write your own driver: If there are no existing libraries or code available for your display, you may need to write your own driver from scratch. This would involve understanding the communication protocol and specifications of the display and implementing the necessary functions and commands in Arduino[. ](https://www.mybkexperience.one/)
