hi all,
#include <LCD.h>
// LCD Segment Mapping
const UInt8 LCD_Char_Map =
LCD_A+LCD_B+LCD_C+LCD_D+LCD_E+LCD_F, // ‘0’ or ‘O’
LCD_B+LCD_C, // ‘1’ or ‘I’
LCD_A+LCD_B+LCD_D+LCD_E+LCD_G, // ‘2’ or ‘Z’
LCD_A+LCD_B+LCD_C+LCD_D+LCD_G, // ‘3’
LCD_B+LCD_C+LCD_F+LCD_G, // ‘4’ or ‘y’
LCD_A+LCD_C+LCD_D+LCD_F+LCD_G, // ‘5’ or ‘S’
LCD_A+LCD_C+LCD_D+LCD_E+LCD_F+LCD_G, // ‘6’ or ‘b’
LCD_A+LCD_B+LCD_C, // ‘7’
LCD_A+LCD_B+LCD_C+LCD_D+LCD_E+LCD_F+LCD_G, // ‘8’ or ‘B’
LCD_A+LCD_B+LCD_C+LCD_F+LCD_G, // ‘9’ or ‘g’
LCD_A+LCD_B+LCD_C+LCD_E+LCD_F+LCD_G, // ‘A’
LCD_A+LCD_D+LCD_E+LCD_F, // ‘C’
LCD_B+LCD_C+LCD_D+LCD_E+LCD_G, // ‘d’
LCD_A+LCD_D+LCD_E+LCD_F+LCD_G, // ‘E’
LCD_A+LCD_E+LCD_F+LCD_G, // ‘F’
LCD_B+LCD_C+LCD_E+LCD_F+LCD_G, // ‘H’
LCD_B+LCD_C+LCD_D+LCD_E, // ‘J’
LCD_D+LCD_E+LCD_F, // ‘L’
LCD_A+LCD_B+LCD_E+LCD_F+LCD_G, // ‘P’
LCD_B+LCD_C+LCD_D+LCD_E+LCD_F // ‘U’
const UInt8 LCD_MAX_CHARS = (sizeof(LCD_Char_Map)/sizeof(UInt8));
// Initialize LCD_A
void initLCD_A(void)
// Clear LCD memory
clrLCD();
// Configure COM0-COM3 and R03-R33 pins
P5SEL |= (BIT4 | BIT3 | BIT2);
P5DIR |= (BIT4 | BIT3 | BIT2);
// Configure LCD_A
LCDACTL = LCDFREQ_128 | LCDMX1 | LCDMX0 | LCDSON | LCDON;
LCDAPCTL0 = LCDS4 | LCDS8 | LCDS12 | LCDS16 | LCDS20 | LCDS24;
LCDAPCTL1 = 0;
LCDAVCTL0 = LCDCPEN;
LCDAVCTL1 = VLCD_2_60;
// Clear LCD
void clrLCD(void)
int i;
for(i = LCD_MEM_OFFSET; i < (LCD_MEM_OFFSET+LCD_MEM_LOC); i++)
LCDMEM = 0;
// Display all segments on LCD
void dispAllLCDSegs(void)
int i;
LCDMEM = 0xff;
// Display character on LCD
void dispChar(UInt8 pos, UInt8 index)
LCDMEM[pos + LCD_MEM_OFFSET] &= ~LCD_Char_Map[8];
if( pos < LCD_NUM_DIGITS )
if( index < LCD_MAX_CHARS )
LCDMEM[pos + LCD_MEM_OFFSET] |= LCD_Char_Map[index];
// Display power level on LCD
void dispPwrLvl(UInt8 lvl)
LCDMEM[7+LCD_MEM_OFFSET] &= ~(BIT1+BIT2+BIT3);
LCDMEM[8+LCD_MEM_OFFSET] &= ~(BIT0+BIT1+BIT2+BIT3);
switch(lvl)
case LCD_PWR_LVL_0:
LCDMEM[7+LCD_MEM_OFFSET] |= (BIT1);
LCDMEM[8+LCD_MEM_OFFSET] |= (BIT0);
break;
case LCD_PWR_LVL_1:
LCDMEM[8+LCD_MEM_OFFSET] |= (BIT0+BIT1);
break;
case LCD_PWR_LVL_2:
LCDMEM[8+LCD_MEM_OFFSET] |= (BIT0+BIT1+BIT2);
break;
case LCD_PWR_LVL_3:
LCDMEM[8+LCD_MEM_OFFSET] |= (BIT0+BIT1+BIT2+BIT3);
break;
case LCD_PWR_LVL_4:
LCDMEM[7+LCD_MEM_OFFSET] |= (BIT1+BIT3);
break;
case LCD_PWR_LVL_5:
LCDMEM[7+LCD_MEM_OFFSET] |= (BIT1+BIT2+BIT3);
break;
// Diplay function F1 thru F5 on LCD
void dispFunc(UInt8 mask)
UInt8 tmp;
LCDMEM[7+LCD_MEM_OFFSET] &= ~0xf1;
if( mask < LCD_FUNC_OFF )
tmp = mask << 4;
if( (mask & LCD_F5) )
tmp |= BIT0;
LCDMEM[7+LCD_MEM_OFFSET] |= tmp;
// Display battery level on LCD
void dispBattLvl(UInt8 lvl)
LCDMEM[9+LCD_MEM_OFFSET] &= ~(BIT0+BIT1+BIT2+BIT3);
switch(lvl)
case LCD_BATT_LOW:
LCDMEM[9+LCD_MEM_OFFSET] |= (BIT0+BIT3);
break;
case LCD_BATT_HALF:
LCDMEM[9+LCD_MEM_OFFSET] |= (BIT0+BIT2+BIT3);
break;
case LCD_BATT_FULL:
LCDMEM[9+LCD_MEM_OFFSET] |= (BIT0+BIT1+BIT2+BIT3);
break;
// Display signal level on LCD
void dispSigLvl(UInt8 lvl)
LCDMEM[9+LCD_MEM_OFFSET] &= ~(BIT4+BIT5+BIT6+BIT7);
switch(lvl)
case LCD_SIG_LVL_0:
LCDMEM[9+LCD_MEM_OFFSET] |= (BIT4);
break;
case LCD_SIG_LVL_1:
LCDMEM[9+LCD_MEM_OFFSET] |= (BIT4+BIT7);
break;
case LCD_SIG_LVL_2:
LCDMEM[9+LCD_MEM_OFFSET] |= (BIT4+BIT6+BIT7);
break;
case LCD_SIG_LVL_3:
LCDMEM[9+LCD_MEM_OFFSET] |= (BIT4+BIT5+BIT6+BIT7);
break;
// Display arrow on LCD
void dispArrow(UInt8 mask)
LCDMEM[8+LCD_MEM_OFFSET] &= ~(BIT4+BIT5+BIT6+BIT7);
if( mask < LCD_ARROW_OFF )
LCDMEM[8+LCD_MEM_OFFSET] |= (mask << 4);
// Display symbol on LCD
void dispSymbol(UInt8 mask)
UInt8 tmp;
LCDMEM[10+LCD_MEM_OFFSET] &= ~(BIT0+BIT1+BIT2+BIT4+BIT5+BIT6+BIT7);
if( mask < LCD_SYM_OFF )
tmp = mask << 4;
tmp |= mask >> 4;
LCDMEM[10+LCD_MEM_OFFSET] |= tmp;
// Display special character on LCD
void dispSpecialChar(UInt16 mask)
UInt16 x;
UInt8 index = 0;
if( mask & LCD_8BC )
LCDMEM[10+LCD_MEM_OFFSET] |= BIT3;
else
LCDMEM[10+LCD_MEM_OFFSET] &= ~BIT3;
for(x = 1; x < LCD_8BC; x <<= 1)
if( x & mask )
LCDMEM[index+LCD_MEM_OFFSET] |= BIT7;
else
LCDMEM[index+LCD_MEM_OFFSET] &= ~(BIT7);
++index;
#if LCD_TEST > 0
void testChar(void)
static UInt8 pos = 0;
static UInt8 index = 0;
dispChar(pos, index);
if( pos++ >= LCD_NUM_DIGITS )
pos = 0;
if( index++ >= LCD_MAX_CHARS )
index = 0;
void testSpecialChar(void)
static UInt16 mask = 1;
dispSpecialChar(mask);
if( mask >= LCD_SPC_CHAR_OFF )
mask = 1;
else
mask <<= 1;
void testPwrLvl(void)
static UInt8 lvl = LCD_PWR_LVL_0;
dispPwrLvl(lvl);
if( lvl >= LCD_PWR_OFF )
else
lvl <<= 1;
void testSigLvl(void)
static UInt8 lvl = LCD_SIG_LVL_0;
dispSigLvl(lvl);
if( lvl >= LCD_SIG_OFF )
else
lvl <<= 1;
void testBatt(void)
static UInt8 lvl = LCD_BATT_LOW;
dispBattLvl(lvl);
if( lvl >= LCD_BATT_OFF )
lvl = LCD_BATT_LOW;
else
lvl <<= 1;
void testFunc(void)
static UInt8 func = LCD_F1;
dispFunc(func);
if( func >= LCD_FUNC_OFF )
func = LCD_F1;
else
func <<= 1;
void testArrow(void)
static UInt8 dir = LCD_ARROW_UP;
dispArrow(dir);
if( dir >= LCD_ARROW_OFF )
dir = LCD_ARROW_UP;
else
dir <<= 1;
void testSymbol(void)
static UInt8 sym = LCD_SYM_DOL;
dispSymbol(sym);
if( sym >= LCD_SYM_OFF )
sym = LCD_SYM_DOL;
else
sym <<= 1;
void testAll(void)
UInt8 x;
for(x = 0; x < 3; x++)
_BIS_SR(LPM3_bits + GIE); // LPM3, enable interrupts
dispAllLCDSegs();
clrLCD();
#endif // LCD_TEST
the above is a LCD display code & m getting the following error:
Error[e46]: Undefined external “main” referred in ?cstart ( C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\LIB\DLIB\dl430fn.r43 )
