LED POWER SUPPLY
Hello there,
Please help me on the following…
I am using this LED power supply for my project.
i am going to light 3 rgb LED strips.
so i am going to pull 3 5v wires out of the first 3 terminals. but i will ground them all to one terminal the (4th terminal) is that ok?
Thank you so much
waleedbc:
is that ok?
Yes
Ross Robotics:
waleedbc:
is that ok?
Yes
Do i need to mind the size of the ground wire tho?
Because im planning to use 4 of this multiple supply where the ground of the circuit is all gonna be common linked at the end to a controller via one wire.
This is the controller
http://g01.a.alicdn.com/kf/HTB1BbHHKpXX … troler.jpg
20-22 Gauge should work fine. Could even use 18 gauge…
