Hello All,
My good friend is in dental school on his own dime and he is looking to save some money. They are required to have a specific type of glasses that has built in lenses called loupes. See the following link for a better description:
It is highly recommended that they use a specific type of these glasses that have lights attached. The kind with lights attached are several hundred dollars more. See the following link for a better description:
As you can see there is an LED lamp that attaches to the glasses with a wire that runs down the frame of the glasses and down to a control and power box that is usually clipped to a belt or kept in the pocket of their coat.
Does anyone have advice on boards or dev kits that include battery clips, LED drivers, maybe some nice connectors (I imagine using a mini-jack would be the easiest), power switch, maybe a lens, and some kind of housing?
I assume someone knows of a very quick and dirty way of doing this so that it will last through his schooling years. Your help is greatly appreciated.
