Where can I find a library that contains the Arduino Nano board (symbol and footprint)? I need it for an Eagle PCB project.
This is the plain vanilla Nano … not other versions.
Thanks in advance.
Thanks in advance.
Hello, have you seen here?
Yes, I did find a Nano footprint and symbol there, and downloaded both to my PC. Thanks.
Now my problem is actually inserting the Nano part into my Eagle library and schematic. I’m finding that very difficult and arcane. :roll:
Any suggestions? I’m running Eagle version 9.6.2.
Sparkyman
I have file ArduinoNano.lbr in my Windows 10 PC, but cannot figure out how to merge/add/drop or whatever… this file into my Eagle (version 9.6.2) library realm and then add this part to a new schematic.
Can some one please tell me how to do this? I keep getting lost in the complex Eagle library structures and procedures.
Here is arduino nano library for proteus: https://www.theengineeringprojects.com/ … oteus.html
You can convert files from proteus to eagle : https://knowledge.autodesk.com/support/ … onics.html
The link says there is no way to Proteus files to Eagle.
Oh no! I heard that it can be directly converted. But looks like it wasn’t true. Actually, the process is not straightforward.
You can convert the PCB layout or footprint in proteus to pdf, then you can convert the pdf to dxf, then you can import the dxf to eagle.
Let’s see if anyone else comes with a better solution. I want to know too.
