Hi folks,
I’m 32 - I’m an electrical engineer - I have been using computers since age 7. I started out on IBM 8088 on MS-DOS 5.1 (I think, we upgraded to 6.0 when it was available). I write software for a living, as well as architect electrical systems at my local utility. I just wanted to make it absolutely clear that I am not a “noob”.
I am experiencing the SAME EXACT phenomena as sylvie369.
When I do a “file->save as” from the library editor, I can see my new custom created .LBR’s within C:\Program Files\EAGLE-6.5.0\lbr
However, if I open up the folder C:\Program Files\EAGLE-6.5.0\lbr from within windows explorer, my .LBR’s are completely missing. I tried going to “Tools->Folder Options” and checked (or unchecked) any and all options that would hide or show files. LBR’s are still missing.
I tried dropping to a command window and manually changing to that directory and ran a “dir” command, still no .LBR’s.
I tried every variation of dir (including the classic dir /AH) and still no .LBR’s.
I go back to EagleCAD 6.5.0 and yup, my libraries are shown in C:\Program Files\EAGLE-6.5.0\lbr.
So I go to Options-Directories within EagleCAD and my libraries dir is “$EAGLEDIR\lbr”.
So I think I’m crazy, I create yet another new library and name it something really unique like “thisisatestlibrary.lbr”. It saves and I can view it at “C:\Program Files\EAGLE-6.5.0\lbr” from within EagleCAD, but again when I go to “C:\Program Files\EAGLE-6.5.0\lbr” from my windows file explorer, the file is still missing.
I’ve tried right-clicking within the folder and selecting “refresh”.
I’ve tried doing a windows search on the ENTIRE HARD DRIVE for partialfilename*.lbr (I only did a partial file name in case I mis-spelled, but I also ran a second full hard drive search for the full file name).
This is on my laptop so there is no second hard drive, no DVD drive, no CD-ROM drive, no USB drive, no network drive. This is all done with the network cable unplugged and the wifi disabled (this is how baffling this issue is).
I’ve literally tried everything and this .LBR cannot be solved.
So, I tried this:
Launch EagleCAD.
Go to your library list, right click and say “open” to open your custom library.
Go to file->save as… to bring up the file save dialog box.
Surf to your lbr directory (if you’re not already there) which for me is C:\Program Files\EAGLE-6.5.0\lbr
Now, scroll down so you can see your .LBR file.
Right-click on it and select copy.
Now, open up a windows file explorer box and surf to your lbr directory again (in my case, C:\Program Files\EAGLE-6.5.0\lbr)
Now, right-click and do a paste. I get this error message:
"Could not find this item.
This is no longer located in C:\Program Files\EAGLE-6.5.0\lbr. Verify the item’s location and try again".
I happen to be in Windows 7 Home Premium 32-bit edition, 6.1, build 7601, service pack 1.
This is by far the most maddening experience I’ve ever had. I’ve spent a couple of weeks building the custom parts library on my laptop, and I am trying to transfer to my main server in my basement for backup - and so that I can do some serious PCB layout on my computer with a larger monitor, and I am simply unable to get the .LBR off this laptop.
Again, I am not a laptop noob, this is a serious bug with either EagleCAD or Windows itself.
I actually registered on SparkFun for the first time to specifically respond to this post since everyone was so skeptical of sylvie369. This is a real bug people - not noob/operator error.
