LilyPad Hardware problem?
New to microcomputing; new to LilyPad.
Loading seems to work…
LilyPad with six-pin FTDI board connected to USB to computer
(like this: http://arduino.cc/en/uploads/Guide/lily … eakout.jpg)
FTDI board LEDs flickers when plugged
Programming software shows port
(Blink example) software compiles
reset button + load displays: Done uploading with…
Binary sketch size: 1124 bytes (of a 14336 byte maximum)
FTDI board LEDs flickers when loading
But…
no pulsing LED on computer board!
Other facts
volt meter shows power to computer (at pins from FTDI)
no LED lit on LilyPad board at any time
after load, 5 volts between + and - pads
Pulsing voltage between power pads and pad 13
I assume that the LED on the board is burnt out.
Thoughts? Suggestions?
Terry.
