LilyPad - LilyTwinkle with more than 4 LEDs ?
Hi there,
I’m starting this project in which I want to attach to some costumes several blinking LEDs. I’m planning to use a LilyTwinkle
https://www.sparkfun.com/products/11364
https://cdn.sparkfun.com//assets/parts/ … 364-01.jpg
and this micro LEDs
LilyPad LED Micro - White (5pcs) - https://www.sparkfun.com/products/10753
https://cdn.sparkfun.com//assets/parts/ … 754-01.jpg
The thing is that I want 20 LED lights (aprox) per costume, wired in parallel, would this work? what power supply do i need?
elunicotomas:
Unfortunately, no. The I/O pins on that device cannot supply sufficient current. You could use multiple LilyTwinkles, as they aren't very expensive.
darrellg:
elunicotomas:
Hey! thanks for the quick response.
I’ll use 5 LilyTwinkles then, with 4 LEDs each, and I guess I’ll have to power each one of them (the LilyTwinkles) with one LilyPad Coin Cell Battery Holder - Switched - 20mm ( https://www.sparkfun.com/products/11285 ) and one Coin Cell Battery - 20mm (CR2032) ( https://www.sparkfun.com/products/338 ), right? or there is a way to power the 5 LilyTwinkles with one source? (a larger battery maybe?)
You could use a LiPower (https://www.sparkfun.com/products/11260) and a LiPo cell. Those are good for up to 150mA, so you’d probably need two. It would cost more, but LiPo cells are rechargeable so long term costs would be lower.
