I’m using the 20x4 LCD connected to a SparkFun Thing (esp32) via i2c Qwiic. The display works fine if I only use the first 3 lines. If I try to use the last line - the screen goes blank.
e.g. this works
Wire.beginTransmission(DISPLAY_ADDRESS1); // transmit to LCD Screen
Wire.write(‘|’); //Put LCD into setting mode
Wire.write(‘-’); //Send clear display command
Wire.println(messageA);
Wire.println(messageB);
Wire.println(messageC);
Wire.endTransmission(); //Stop I2C transmission
this does not - blank screen
Wire.println(messageD);
I have tried sending the
Wire.write(0x05); //Put LCD into 4 line mode
The screen shows Lines 4 Width 20 on boot up - but still won’t display anything when I attempt to include the 4th line.
any clues would be greatly appreciated.
