Hopefully someone with some vb.net experience is reading this… ![]()
I am trying to listen to the COM3 port and display the output in the TextBox.
If I understood correctly I will have to implement this by using eventhandlers, delegates.
I tried following these articles:
http://www.informit.com/articles/article.aspx?p=23020
http://www.xtremevbtalk.com/showthread.php?t=159976
And this is the code I came up with…
Unfortunately it doesn’t display anything. App just starts display “True” and no data is being displayed.
I am monitoring Arduino platform which I know is sending data constantly.
Imports System.IO.Ports
Imports System.Text
Public Class ArduinoSerial
Public Event ReceivedSerialData(ByVal data As String)
WithEvents Serial As SerialPort
Dim data As String
Private Sub ArduinoSerial_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Serial = My.Computer.Ports.OpenSerialPort("COM3", 9600)
TextBox.AppendText(Serial.IsOpen & vbCrLf)
End Sub
Private Sub Serial_DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles Serial.DataReceived
RaiseEvent ReceivedSerialData(data)
End Sub
Public Sub DisplaySerialData(ByVal data) Handles Me.ReceivedSerialData
TextBox.AppendText(data & vbCrLf)
End Sub
End Class
I am really new into the vb.net. I am sure there are some horrible mistakes with this code but I am kind of stuck for the past 2 days on this one. Maybe someone could point me in the right direction. Thanks! ![]()
