Hello guys and girls
I would like to make a load cell to be used with pulling force. I downloaded the code from project on sparkfun website. But I also need to add a button that if you press it will shows you a peak pull force. Is this possible?
Simple code for this:
if ( Force > PeakForce ) {
PeakForce = Force;
and, of course, you will need some code to examine the pushbutton and react to it
<Well, I was going to use code tags but the most recent change in the forum neither recognizes them nor does the full editor have any formatting code>
<edit: now the formatting stuff is there but the preview doesn’t format for the tag>
