I assume the maximum voltage that can be read on the logomatic ADC lines is 5.0V. Is that correct?
I couldn’t find anything in the instructions/manual.
BTW - this is a cool device!! ![]()
cavjg:
Logomatic isa 3.3v device, so the maximum A/D value will be at 3.3v. Check the data sheet to see if the analog ports are even safe to run 5v in to.
Glen Overby
Thanks Glen. You are correct, it is 3.3V and the maximum ADC voltages would be 3.3V.
I’ll have to use voltage dividers… ![]()
