I am currently using the GNUARM toolchain for a project that is nearing completion and noticed that their website (www.gnuarm.org) now redirects to the yagarto main page (www.yagarto.de). Other than the main page, other pages on gnuarm.org still load correctly. Neither page appears to give any explanation for this. Google didn’t provide much help either.
Does anyone know the story behind this? Has GNUARM been discontinued? I’m a little nervous going forward with a toolchain that may not be supported in the future.
GNUARM is a repackaging of GNU build tools. YAGARTO is the same thing. The differences are the libc builds, and versions of the tools. If GNUARM works today, it will continue to work. If you want to update the tools continuously, move to Yagarto (or CodeSourcery) or roll your own for maximum customize-ability.
gnuarm.com still works. You could also build your own compiler/c library, this is not that hard and this setup is very customizable. gnuarm.com is probably the best place to start with such endeavour. This way you could matain your own toolchain and keep it updated.
theatrus:
Knowing your tool makes you much better at using them
absolutely true.
however, in a resource constrained world, spending lots of time on your tools means little time for you to use your tools to do what you use your tools for.
tools are a means to your goal, not the goal itself.
