Hello all,
I am doing an automotive lighting project; adding EL gauge overlays. The overlays come with both frequency and dimming switches, but it is my preference to control the brightness with the OEM dimming buttons (which are up/down buttons).
If I knew what the load limitations were on the OEM dimming circuit (controlled by CANBUS/BCM), this would not be an issue - I would just power the inverters directly off that brightness controlled circuit - but I cannot find that information.
That leaves me with figuring out how to provide the INPUT of the dimmable circuit and use a controller to harness the power of a higher current load circuit (like IGN 12v+) to power the inverters. Does anyone know if such a module - that uses a low current 0-2vdc input trigger to control the output voltage of a 12vdc high current source, and output the same voltage? Essentially, this:
#$#&$*( pic didn’t upload.
