Looking for an Eagle library for SD socket
Hi All, I’m looking for an Eagle library for an SD card socket, something like these:
Molex & Digikey info:
http://search.digikey.com/scripts/DkSea … 19093CT-ND
http://www.molex.com/pdm_docs/sd/5025700893_sd.pdf
No luck so far, can someone who knows where to find these help me out?
Thank you!
If you still need this, I can export and post ours for you. Post here if needed.
Ted
tCm:
Ted
Yes, I do still need this. Thank you very much!
Attached to this post is an EAGLE lbr with our SD socket devices.
It looks like you need microSD, however. It happens that someone posted one this morning… from France. See ‘con-molex-microsd.zip’ from the [library download page at Cadsoft
[Direct link to microSD library at Cadsoft I haven’t checked it but you can email them to ask if the footprint has been QA’ed
Ted](ftp://ftp.cadsoft.de/eagle/userfiles/libraries/con-molex-microsd.zip)](CADSoft Finanzportal - CADSoft Finanzportal)
No I’m looking for standard SD card, thank you very much!
I only suggested the microSD because the [digikey part you linked to is a microSD socket. Welcome!
Ted](http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=WM19093CT-ND)
tCm:
Ted[/quote]
Oh that was my mistake! Thanks Ted!
BTW, who makes this part? In the prototype I used the library and part here on SparkFun but that part seems to not be the best :-(](http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=WM19093CT-ND)
There’s two parts in the standard SD library I attached, one each from 3M and AVX. The Digikey part numbers are in the Devices. You can view this by going into the Library then Device, or using Info tool on the part added to the schematic/board.
Ted
Ted, you’re the best! The 3M was exactly what I was hoping to use!
Thanks again!
Jim
