Ive searched thru the products for “bluetooth” and not sure if either of them will work for what im trying to accomplish… Ive seen a few videos on youtube that take a bluetooth headset for your phone and modify it to do other tasks, the most recent that i saw was a garage door opener, which was pretty cool… are the bluetooth boards like the one found in the headsets available? if so which product would it be?
If its not, is there another product that would sync/pair with my phone(Google Nexus) to play around with some ideas…
Any suggestions or links would be great to review.
thanks
Just made my own remotely controllable relay (garage door opener) with http://www.sparkfun.com/products/10393 and http://www.sparkfun.com/products/11042. Works wonderfully with the Nexus. If you start looking at the solid state relay (re: not the one I linked to), just note that it is only to be used with AC and probably won’t handle the 12V trigger for your garage door opener as you would hope but would be fine for any AC controller projects you might have in mind.
If you’re new to android and want something up and running quickly check out http://ai.kittywolf.net/index.php/BlueT … nt_Connect. The app invetor is now hosted by MIT at http://beta.appinventor.mit.edu/ and work fairly well.
