Looking for Mercury API 1.37.3 (Non-BILBO) for M6E Nano
Hello SparkFun community,
I’m currently trying to set up the M6E Nano on a Raspberry Pi 4 using the Python wrapper with Mercury API. While following the recommended setup, I’ve run into trouble locating the correct Mercury API version.
The JADAK website only provides BILBO builds (1.37.2.24, 1.37.4.8, etc.), which appear to be intended for M7E experimental firmware, not the M6E. As a result, I’m not sure whether they’ll work reliably with my M6E Nano.
Does anyone know where I can download the mainline Mercury API 1.37.3 (non-BILBO)? Or has anyone here successfully used the BILBO versions with the M6E Nano?
Any help or guidance would be greatly appreciated!
Thanks in advance,
Facundo Aguirre
P.S: the links at “https://www.jadaktech.com/resources/rfid-document-library/“ dont work!! when you click, for example: “ThingMagic® Mercury API 1.37.2“ you get “mercuryapi-BILBO-1.37.2.24“.
You might be able to scrounge up a copy using the Wayback Machine (if you can parse/find the right link). You also might be able to get the specific version you’re after by emailing Jadak directly?
just uploaded for you to mercury. will be there for couple of days.
