LoRa module RFM95W
I am reaching out because I am making a PCB design on which I want to use RFM95W 915Mhz Lora module made by Sparkfun. I took this model from Sparkfun_RF EAGLE library and I have made the connections to it with ATSAMD51J19A (having ARM cortex M4) micro-controller, made by Microchip technology. So I have few questions as follows:
  1. Can you somehow tell me if your RFM95W 915Mhz Lora module would work with above mentioned MCU since I know there is a product in your website which is using a lower version, SAMD21G18A? So i wanted to know if you could tell me the compatibility with ATSAMD51J19A?
  2. I am making a partlist for my PCB design , but I couldn’t find just the RFM95W 915Mhz LoRa module in your website?
Looking forward to hear the reply from you soon.
Thanks!!
  • Akshay Sachdeva
A great place to get started would be looking through our GitHub Repo for the Pro RF: https://github.com/sparkfun/SAMD21_Pro_RF
Unfortunately, we don’t carry it on the store front. You should be able to find it through Mouser or DigiKey.
I hope this helps point you in the right direction.
