LoRa RFM96x wiring to a NodeMCU
I’m a Junior in high school and I am currently trying to retrieve temperature data from a nearby river. I am using The LoRa RFM96x to transmit the data from the river to a receiver that is based in my school. The data is then sent to a google sheet that I have created. The only problem at the moment is the wiring between the NodeMCU and the RFM96x is not working. I’ve checked my code and it works when the RFM96x is connected to an Arduino UNO. If anyone knows the wiring schematic for these two boards let me know. Thank you in advance.
  • Shane
which LoraShield are you using ? ( Dragino like I use ?)
what sketch are you using ?
how did you wire between UNO and the RFM96x?
regards,
