Associates,
Using the example code from here:
https://learn.sparkfun.com/tutorials/1w … er-example
When I compare the receiver’s RSSI (Received signal strength indication) to the results from the published example, the Power I pick up is way low.
With my TX set to 17dBm in the SX1276, which means there is 27dBm coming out of the EBYE …
My Receiver reports about -63dBm RSSI for me vs -16dBm in the examples.
-My boards are a meter 1meter apart.
-The PaCFG is confirmed at 0xFF, which translates to PA_Boost Pin (Good) and Pout - 17dBm.
-The official ¼ wave antennas are attached, the ones with the cool 90degree bend.
-That little 0_ohm Jumper is happily connected to the antenna SMA connection.
==> While I debug, I ask for any other ideas for what I should be looking at.
Gratefully,
MARBanak
