I’m making a board that will contain an LPC2103 unit, and since timing is not critical, but height is, I would like to use a surface mount ceramic resonator.
From reading some data sheets on ceramic resonators w/o caps I have found that the necessary loading capacitor sizes can vary widely across chip families/voltage ranges.
If these aren’t sized properly could the oscillator circuit fail to start, or would the frequency accuracy just be reduced?
That is a nice low profile package but Alas they don’t seem to have it in stock at digikey. I’d rather keep everything from a single source, but if I’ll still keep them in consideration.
Abracon also makes a variety of low-profile xtals, similar to the Citizen ones, but more commonly available. Digikey doesn’t carry them (last I checked), but you can get them at Mouser…
