Part of cstartup file:
__iar_program_start:
?cstartup:
I_Bit DEFINE 0x80 ; when I bit is set, IRQ is disabled
F_Bit DEFINE 0x40 ; when F bit is set, FIQ is disabled
#define VIC_INT_ENABLE 0xFFFFF014
; Disable all interrupts
ldr r0,=VIC_INT_ENABLE
mov r1,#0xFFFFFFFF
str r1,[r0]
; Execution starts here.
; After a reset, the mode is ARM, Supervisor, interrupts disabled.
; Initialize the stack pointers.
; The pattern below can be used for any of the exception stacks:
; FIQ, IRQ, SVC, ABT, UND, SYS.
; The USR mode uses the same stack as SYS.
; The stack segments must be defined in the linker command file,
; and be declared above.
mrs r0,cpsr ; Original PSR value
bic r0,r0,#MODE_MSK ; Clear the mode bits
orr r0,r0,#SVC_MODE ; Set Supervisor mode bits
msr cpsr_c,r0 ; Change the mode
ldr sp,=SFE(SVC_STACK) ; End of SVC_STACK
orr r0,r0,#UND_MODE ; Set Undefined mode bits
ldr sp,=SFE(UND_STACK) ; End of UND_MODE
orr r0,r0,#ABT_MODE ; Set Data abort mode bits
ldr sp,=SFE(ABT_STACK) ; End of ABT_STACK
orr r0,r0,#FIQ_MODE ; Set FIR mode bits
ldr sp,=SFE(FIQ_STACK) ; End of FIQ_STACK
orr r0,r0,#IRQ_MODE ; Set IRQ mode bits
ldr sp,=SFE(IRQ_STACK) ; End of IRQ_STACK
bic r0,r0,#MODE_MSK | I_Bit | F_Bit ; Clear the mode bits
orr r0,r0,#SYS_MODE ; Set System mode bits
ldr sp,=SFE(CSTACK) ; End of CSTACK
