LPC2124 CrossWorks problem
I have a LPC2124 header board. I’m trying to debug the program under the CrossWorks via your JTAG. When the code is placed in the RAM, it works correctly. When i try to debug in Flash, it doesn’t work. The download is ok, the verification is ok, but every time “can’t locate to instruction” message appears. Any ideas? 8)
send Rowley a message, we had the same problem it was few things to touch up and it start working
this is related to some LPC2124 bootloader issue which they work around
Tsvetan
