Hi
This post is edited because my problem with MMC was solved, I had problem with my connections
Now I want to copy data from MMC/ micro SD to a USB flash drive. I know the MCI feature of LPC, but what features I should use to connect a USB flash frive to LPC23xx?
What solution is the easiest way to do this?
For which solution there are sample code/ examples?
Does the device have to have USB Host feature?
Any hints?
Thanks in advance for your help
