Hello ,
I have a board based on the LPC2478.I wish to test the ethernet on this board.
Is there any code example available to just ping the board and test it?
TIA
Thomas
Hello ,
TIA
Thomas
If the Ethernet connections and components match the olimex LPC2478-STK, you can try downloading the demo hex file from [utasker. Just look for the the files under LPC24XX.
You can use the serial port to change the IP address.](µTasker Test Software and Demos)
