LV-MaxSonar-EZ4 Questions
Just been playing with the EZ4, the documentation states that it will detect an object from 6 to 255 inches. Mine only works up to 14 inches and the analog output only reads 1.67 or 1.54 volts continuous. Input voltage is 5 volts.
Do I have a bad sensor?
EDIT
Also, is there any way to water proof this bad boy?
Update,
Unit found to be defective and is being replaced by Maxbotics NC
:slight_smile:
