How about dear.
First of all, thank you for the contribution.
I am an electronic engineering student and I am about to start a project.
The query is: For the M6E nano to be able to identify tags I must connect.
-M6E NANO - RASPBERRY PI (5V - 5V) (GND - GND) (TX - GPI02PIN3)) (RX - GPIO3PIN5) ?
Where would you connect the antenna?
In order for it to start identifying tags, should I purchase any other product?
Could the antenna be a coaxial cable?
-In the m6e nano, what would be the antenna pin?
:roll:
thank you very much again
Greetings
There is good documentation on https://www.sparkfun.com/products/14066 ( click on DOCUMENTS middle of page righthand). Look to the HOOKUP guide.
You will find all the Antenna information.
While your connection to the Raspberry is correct, be aware that the M6E is very sensitive to a strong power supply. The wall wart that is normally used with a Raspberry PI is strong enough but good enough for testing.
Make sure to order tags ( e.g. https://www.sparkfun.com/products/20228)
As for software, you will need the ThingMagic MercuryAPI from Jadak. It has good examples in C, Java, C# ( https://www.jadaktech.com/resources/rfi … t-library/)
The M6E can get hot quickly, especially with higher powers. It might need a cooling block
