I was following the tutorial detailed in https://learn.sparkfun.com/tutorials/us … troduction. When I ran the make bootload command, I initially got the following output:
ajay@ajay-Predator-G3-571:~/Desktop/SparkfunEdge/AmbiqSuite-Rel2.0.0/boards/SparkFun_Edge_BSP/examples/example1_edge_test/gcc$ make bootload
Compiling gcc …/src/main.c
Compiling gcc …/…/…/…/…/devices/am_devices_led.c
Compiling gcc …/…/…/…/…/utils/am_util_delay.c
Compiling gcc …/…/…/…/…/utils/am_util_faultisr.c
Compiling gcc …/…/…/…/…/utils/am_util_stdio.c
Compiling gcc startup_gcc.c
Compiling gcc …/src/tf_adc/tf_adc.c
Compiling gcc …/src/tf_accelerometer/tf_accelerometer.c
…/src/tf_accelerometer/tf_accelerometer.c: In function ‘platform_read’:
…/src/tf_accelerometer/tf_accelerometer.c:336:31: warning: assignment from incompatible pointer type
iomTransfer.pui32RxBuffer = bufp; // Link in the RX buffer
Compiling gcc …/src/tf_accelerometer/lis2dh12_reg.c
Linking gcc bin/example1_edge_test.axf
Copying gcc bin/example1_edge_test.bin…
…/…/…/…/…/tools/apollo3_scripts/create_cust_image_blob.py --bin bin/example1_edge_test.bin --load-address 0xC000 --magic-num 0xCB -o bin/main_nonsecure_ota --version 0x0
/bin/bash: …/…/…/…/…/tools/apollo3_scripts/create_cust_image_blob.py: Permission denied
Makefile:193: recipe for target ‘wired_update’ failed
make: *** [wired_update] Error 126
I then went to change the permission of create_cust_image_blob.py (ran chmod +x create_cust_image_blob.py) and had the following output
File “…/…/…/…/…/tools/apollo3_scripts/create_cust_image_blob.py”, line 6, in
from Crypto.Cipher import AES
ImportError: No module named ‘Crypto’
I followed the tutorial in renaming /tools/apollo3_scripts/keys_info0.py and changing the permissions for bsp/tools/uart_wired_update_sparkfun.py . Is there a reason I may experiencing this?
