MAX1709 EUI+
I need some information about the MAX1709 EUI+. Reading the data sheet I didn’t understand much. Any information is appreciated. Also if someone has any schematic example using the MAX1709 EUI+ I will be glad to check it.
Maxim has an eval kit (with schematic and pcb layout) at http://datasheets.maxim-ic.com/en/ds/MAX1709EVKIT.pdf
There’s also a project at http://translate.google.com/translate?h … n%26sa%3DN
where someone uses it for an LED light.
/mike
