if i use the OpenOCD Feature to send the Memory-Map to my GDB the command “info mem” returns:
~“Using memory regions provided by the target.\n”
~“Num Enb Low Addr High Addr Attrs \n”
~“0 y \t0x00000000 0x00100000 rw nocache \n”
~“1 y \t0x00100000 0x00140000 flash blocksize 0x4000 nocache \n”
~“2 y \t0x00140000 0x100000000 rw nocache \n”
I use this standard cfg “openocd -f interface/olimex-jtag-tiny.cfg -f target/sam7x256.cfg”.
Where does OpenOCD get the MemoryMap from? I think this map is not correct because:
region 0 could be flash before remap command, after it´s RAM!?
region 1 seems to be ok, but what does the blocksize mean?
region 2 is RAM, Abort and Internal Peripherals!? rw?
Could anyone please help me to understand where these values come from, and why.
For now i use the “gdb_memory_map disable” OpenOCD Command and with this the debugging gets nomore DataAborts…I just want to unterstand whats going on with this “auto memory map”…
Thank you!
