How can I make sure that the sensor is not defected and working well?
I connected the sensor and tried to run the basic example on archive but the out put print is the sensor can’t be connected.
Since this sensor is a 3V and my other parts sharing 5V., should I put resistor between SDA and SLA and pressure sensor to reduce the voltage?
If your post is about the Sparkfun Qwiic Micropressure Sensor, follow the “Getting Started” tutorial very carefully.
You MAY NOT use that sensor with a 5V processor, without an I2C level shifter. If you have, the sensor may already have been destroyed.
