I need help finding a microchip that will work for my project. I need a chip that gives me a momentary, (less than 1 second), continuity between two points, when a change happens in a normally latched on, and latched off connections. I’m new to the chip search, where do I start?
Any microcontroller should be suitable.
Or a 555 and a MOSFET
Or a suitable power supply, a continuous rotation servo, an offset cam mounted on the servo, and a lever switch ![]()
