Microview current draw @ 5V?
Hi all,
I haven’t found it on a datasheet yet. What is the Microview’s current draw when powered by 5V?
I realize that it’s dependent on OLED activity, but what’s typical / worst case ?
Hi Schema,
Display off, about 3uA
50% Display on about 11-13mA
100% Display on about 18mA
The current draw also depending on what is connected to MicroView, the efficiency of the loop().
Check this out if you need more
https://www.sparkfun.com/tutorials/309
Cheers
JP
Oh, that’s excellent, thanks.
I have an idea for an embedded application that only had 100mA current available - looks like I’ll have tons of margin. Will try it this weekend. Thanks!
For those that is interested in more details, please check out [Chapter 10 of ATmega328P datasheet and also this quick tutorial from Sparkfun https://www.sparkfun.com/tutorials/309](http://www.atmel.com/images/Atmel-8271-8-bit-AVR-Microcontroller-ATmega48A-48PA-88A-88PA-168A-168PA-328-328P_datasheet_Complete.pdf)
