Mini Button Pad Set White: Wrong Eagle File!
I tried to get the Eagle File from this button and it is the Board file and wiring diagram file.
http://www.sparkfun.com/commerce/produc … ts_id=8998
Isn’t it suppose to be the file you use to create the actual button it self out of rubber silicone or what ever material they used to make it?
How can I get this file?
