Does anyone have the example code for MLX90614 Evaluation Board in SPI mode? The example code in the library is for I2C mode, did anyone did it in SPI mode and hence have a source code for it?
I am actually not seeing an SPI code example for this sensor as far as I can tell.
I would highly recommend that you try asking the Arduino community if anyone there knows of a library:
I hope this helps and I wish you luck.
