MLX90632, terrible response and accuracy?
I’ve been trying to get a MLX90632 infrared temperature sensor running on Arduino using the Sparkfun Library: https://github.com/sparkfun/SparkFun_ML … no_Library
The accuracy is horrendous, I’ve tried the normal and medical accuracy sensors and the response is very slow. The sensor temperature almost changes faster than the object temperature.
Has anyone used this sensor with this library and had accurate results? I’ve tried two of the sensors and both respond the same. I can’t find a fault in the library but this sensor is supposed to be accurate within at least 1 degree and it’s no where near this.
I have the Melexis MLX90614 and it is highly accurate and responds immediately
