Mounting PCB's with adheasive
I have a situation where space is too tight for hardware to mount a board. I’m forced to use some type of adhesive.
  • What type is recommended?
  • What should I watch out for?
  • What is the solder mask made out of anyways?
Solder mask is a type of resin. It’s pretty tough.
Leon
Silicone is a good light duty adhesive that can take the heat and is easily removed if rework is needed. If you need strength then epoxy is pretty common in electronics. Hot glue is also an option.
