I ordered the LARGE 2.4 Ghz Duck antenna, figuring I get better range than with the smaller version.
But, I’m worried about the mechanical stress the antenna is going to put on the transceiver card (WRL-00705), especially if it’s just soldered into my pcb. There’s a lot of leverage there, and just a little abuse seems like it could cause a problem.
So, a couple of questions.
Will the big antenna really help range, given I’m communicating with the Nordic FOB? Maybe I should just use the small one. The big one seems bigger than a 2.4 Ghz wavelength.
The top and bottom copper of the WRL-00705 seem both to be ground for the 1/2 of the pcb near the antenna. Can I safely drill a hole through the board in this area so I can securely mount the tiny pcb to the chasis, so strain will be removed from the connection between the WRL-00705 and my pcb? (I’ll use a ribbon cable between my pcb and the WRL-00705).
Any better ideas?
Dave Thomas
