I thank you for all of the help that I have received.
I need to add the MP3 TRIGGER to my existing Arduino UNO.
I need to select trigger and volume settings via. I2C.
My initial I2C interconnection is MP3 TRIGGER: GND, 3.3V, SDA, SCL to ARDUINO: GND, 3.3V, A4(SDA), A5(SCL)
I this the correct I2C interconnection?
I would like to hard wire the MP3 TRIGGER into all of our ARDUINO controlled systems.
Lee J. Bernasek
Engineering
IML Corp.
869 Pickens Industrial Dr, Suite 15
Marietta, GA 30062, USA
Mobile: 912-674-8537
bernasek@tds.net
www.imlcorp.com
              That should be the correct wiring. Have you confirmed if this has worked in a small unit test?
              I have not used this interconnection. The setup came from my research for an answer to the correct wiring configuration.
I appreciate your prompt assistance. The MP3 TRIGGER is proving to be a very flexible and reliable component in our audio systems.
Lee J. Bernasek
Engineering
IML Corp.
bernasek@tds.net
www.imlcorp.com
