MSP430-449STK - LCD Specs?
Does anyone here happen to know (or have) the specs for the LCD that is provided with the MSP430-449STK, and is willing to share?
I purchased the starter kit, but am having trouble getting data to display correctly. I can get close using the example code from TI, but it behaves erratically. I checked the schematic, and it appears to be slightly different than what is outlined in the examples from TI. The schematic simply lists it as ‘LCD’ with no manufacturers part#…
-Dozer
you can check the schematic on http://www.olimex.com/dev
every pin is named, also the sample code have definitions for the LCD
what else information is needed
Tsvetan
Tsvetan,
I have the sample code now and will use the definitions contained therein. I was not aware of the sample code until I visited your site… Thanks for the info :slight_smile:
-Dozer
Hi all
I think that the last board version LCD in the MSP430-449STK-B is not correct with the schematic.
I’m having problems acess to this segments:
  • AC ~
  • triangular UP
  • plus and less (menor segments)
Please help…
Best Regards
Pendragon
Does anyone here have a sample code in C to drive the LCD?
The LCD is conected with no logic at all, so is a little dificult to make some algorithm to control the LCD.
Thanks in advance,
Américo Dias
it’s hard to have logic with static drive LCD
the assembler code have definitions which may be used in any language
Best regards
Tsvetan
Thanks for your support.
After a lot of work i created a algorithm in C to write to the LCD. It have 1K size but is not problem for me.
I could share the code if someone need. my email is(adias.corsisa@mail.telepac.pt).
(Sorry my english)
Américo Dias
The entire code to control de LCD comes with CrossStudio for MSP430. http://www.rowley.co.uk.
Américo Dias
Please, i have a board maned MSP430-449STK-B by Olimex.
I need the hardware domumentation of this borad and LDC module.
On the site www.olimex.com only have documentation for STK2 and it is not the same.
Thank´s Valter Rosa
