Multi color latching push button switch
Hello! I am very new here. I searched out this forum because I am trying to build a prototype of a new board game. I wanted to make the game electronic but I needed to see if it can be done. I wanted to make use of lights to designate tokens. There are basically three colors used in the game. I wanted the player to be able to press on a light to change it to their color.
Is there a latching switch that can rotate between three colors when pressed? I see plenty that will maintain a single color but I’m not coming across anything that would move to a different color. Wanting to see if this is possible.
Hope this makes sense. Thank you all!
Have a look at the Qwiic Twist:
You can click the button (as well as twist it). The LED color can be changed via I2C commands.
