Multiple Witilts Question
Hey,
First I’d like to say the Witilt is a very nice piece of hardware!
I’d like to ask if its possible to use multiple witilts simultaneously.
At this link:
http://protolab.pbwiki.com/WiTiltHey,
I found the following:
“You can connect at most two Witilts to a computer using the blueSoleil software. The program only allows you to open a max of 2 incoming bluetooth serial port connections. However you can have three or more Witilts so long as you only have at most two connected at the same time.”
I’d like to use 3 witilts together and was wondering if anyhow had a solution or idea’s about this.
Rgds
Anthony Dalton
