NAU7802 Qwiic Scale: resolving 1.33 µV changes at 320 SPS
I own two SparkFun NAU7802 Qwiic Scale breakout boards and would appreciate some guidance on their practical resolution at 320 SPS.
Each board will read a separate Dini Argeo CPX7500 load cell:
  • Rated capacity: 7,500 kg.
  • Sensitivity: 2 mV/V.
  • Proposed external bridge excitation: 5 V.
  • Full-scale differential output: 10 mV.
  • Therefore, a 1 kg load change produces approximately 1.33 µV.
The application is an agricultural weighing system. I want to collect 320 samples per second from each board, then digitally filter the readings to produce one weight estimate per second.
Nuvoton specifies 150 nV RMS input noise at 80 SPS and gain 128, but I could not find equivalent figures for 320 SPS.
My questions are:
  1. Do you have measured input-referred noise figures for your board at 320 SPS and gain 128?
  2. Would resolving a 1.33 µV change be realistic at that rate? Would you recommend 320 SPS with subsequent filtering or 80 SPS?
  3. Is external 5 V load-cell excitation compatible with this breakout board as supplied? Both signal inputs would sit near 2.5 V relative to ground. If modifications or a different power/reference arrangement are required, please specify them.
I understand that vibration and installation noise will affect the complete system; my immediate question concerns the electrical capability and correct configuration of the breakout board.
