Riti
1
I want to map the values from AS726x measurement values
map(value, fromLow, fromHigh, toLow, toHigh)
I have not been able to locate min/max values that are reported not whether this range is impacted by GAIN setting.
Please help me into this.
Altering the GAIN should alter the readings; I’m not certain I fully understand the question but the 2 examples you probably want to look at/try experimenting with are https://github.com/sparkfun/SparkFun_AS … ttings.ino and https://github.com/sparkfun/SparkFun_AS … Values.ino
Hope this helps!
