I am having a problem with errors when compiling my code now. Im using arduino 0018 i have these libs installed
:NewSoftSerial,Streaming,Tinygps,sdfat
here is my code:
Written by Jonnyboy323
Version 1.0
GPS Data Logger
10/17/11
//Add the Mikal Hart Libraries
#include <NewSoftSerial.h>
#include <TinyGPS.h>
//Add the SdFat Libraries
#include <SdFat.h>
#include <SdFatUtil.h>
#include <ctype.h>
//Create the variables to be used by SdFat Library
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
#define BUFFSIZE 65
char buffer[BUFFSIZE]; //This will be a data buffer for writing contents to the file.
char in_char=0;
char filename=“trip.txt”;
//Intialize TinyGPS and NewSoftSerial
TinyGPS gps;
NewSoftSerial nss(3, 2);
//Intialize GPS variables
long lat, lon;
float flat, flon, fspeed, falt, fcourse;
unsigned long age, date, time, chars;
int year;
byte month, day, hour, minute, second, hundredths;
unsigned short sentences, failed;
bool newdata = false;
bool feedgps();
void setup()
nss.begin(4800); //GPS’s Buad Rate
pinMode(0, INPUT);
pinMode(1, OUTPUT);
pinMode(10, OUTPUT);
pinMode(13, OUTPUT); //LED Pin
digitalWrite(13, LOW); // Ensure LED starts as off
card.init(); //Initialize the SD card and configure the I/O pins.
volume.init(card); //Initialize a volume on the SD card.
root.openRoot(volume); //Open the root directory in the volume.
//Create file with defined filename
file.open(root, filename, O_CREAT | O_APPEND | O_WRITE); //Open or create the file ‘name’ in ‘root’ for writing to the end of the file
file.print(“year,month,day,hour,minute,seconds,latitude,longitude,altitude(ft),speed(mph),course\n”); //Write the header array to the end of the file.
file.close(); //Close the file.
// flash LED 5 times when setup is finished
for (int i=0; i<4; i++){
digitalWrite(13, HIGH); // set the LED on
delay(1000); // wait for a second
digitalWrite(13, LOW); // set the LED off
void loop()
bool newdata = false; // check if data is coming in
if (feedgps())
newdata = true;
if (newdata)
//Pull gps data
gps.f_get_position(&flat, &flon, &age);
feedgps(); //used to keep gps “awake”
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
feedgps();
falt = gps.f_altitude();
fspeed = gps.f_speed_mph();
fcourse = gps.f_course();
feedgps();
//Break up float values into whole numbers(var) and decimals(var1) to be added to data
int flat1 = (flat - (int)flat) * 10000;
int flon1 = (flon - (int)flon) * 100000;
int alt1 = 0;
if (falt >= 10000000.00){ //when gps cant get altitude
falt = 0; //set to 0
}else{
falt = falt * 0.032808399; //cm to feet
alt1 = (falt - (int)falt) * 10;
int fspeed1 = (fspeed - (int)fspeed) * 10;
int fcourse1 = (fcourse - (int)fcourse) * 10;
//Create then write the char array “buffer” to the end of the file
file.open(root, filename, O_WRITE | O_APPEND); //Open the file in write mode and append the data to the end of the file.
sprintf(buffer, “%d,%d,%d,%d,%d,%d,%0d.%d,%0d.%d,%0d.%d,%0d.%d,%0d.%d\n”, year,month,day,hour,minute,second,(int)flat,abs(flat1),(int)flon,abs(flon1),(int)falt,abs(alt1),(int)fspeed,abs(fspeed1),(int)fcourse,abs(fcourse1));
file.print(buffer); //Write the ‘contents’ array to the end of the file.
//flash LED
delay(500);
delay(10000); // wait 10 sec before writing next data point
bool feedgps()
while (nss.available())
if (gps.encode(nss.read()))
return true;
return false;
I get these errors when compiling:
arduino-0018\libraries\NewSoftSerial/NewSoftSerial.h:4:20: error: Stream.h: No such file or directory
and
arduino-0018\libraries\NewSoftSerial/NewSoftSerial.h:53: error: expected class-name before ‘{’ token
any idea whats causing these erroe
