Hello all,
I’m trying to update a code from an older Arduino environment to 1.0.1 (I’m also using Arduino R3). The problem I’m having is understanding how to change following Serial related code parts:
(This part seems to be fine, after I updated include to SoftwareSerial)
#include <SoftwareSerial.h>
#define SerInToArdu 8
#define SerOutFrmArdu 12
SoftwareSerial mySerialPort(SerInToArdu,SerOutFrmArdu);
The BYTE seems to be discontinued, so would it work to do mySerialPort.print(0x77); or does it have to change .print to .write or even value isn’t correct?
mySerialPort.print(0x77, BYTE);
I read that Serial.print changed to .write, does the same apply to .println? If so, would Serial.print ("Repeat = "); work just by changing Serial.print to Serial.write (leaving the bracketed value as it is) ?
Serial.println (repeatcount);
Edit Forgot to mention, this is to do with making a 7-segment serial display to work from sparkfun. (http://www.sparkfun.com/products/9766)
