NEO6 CR LF
Hi, First post.
I have a project where a GPS sends NMEA sentences to a programmed PIC, which acts on the information, and send the result to a terminal (Teraterm)
I use a NEO6, a Laptop (Linux) with (Cute.com) sent to a log. Then in test when the NMEA DATA is sent to the PIC, the lines should left justify, but sometimes many lines are sent as one instead of separately. It is possible that it is CR LF, or timing causing the problem.
How do I see the DATA, so that I can correct the faults, please.
Camerart.
