Ok, so this week I bought a new arduino fio, and also a usb explorer as well as 2-series1 xbee’s.
Im using arduino IDE 18
Here is what I have done.
solder the usb explorer rts-dio3 together. and my fio was soldered already from sparkfun
powered them up (duh, just have to make sure you guys know too)
flashed the xbee chips firmware and settings in x-ctu with bboth indivdually as tutorials state and also raw uploading the saved files (end-device, and coordinator)
I check the values for both in x-ctu AND the xbeeconfig util. they all check out fine.
EXCEPT I cannot no matter what I do use the discover function in x-ctu.(pissed about that one)
- I go to flash properly (right com’s and board style) and it starts communicating and looks GREAT. and then it errors on me in the arduino IDE.
And then this crap.
avrdude: stk500_getsync(): not in sync: resp=0xfc
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Also, I tried all last night to upload as well, and it DID work, ONCE!@#!@#!
It worked when I started uploading right as I turned on my fio, within less than 1 second of turning the fio on I started u/ling.
Nothing else so far.
As a history of me and arduino goes, a couple months ago I got a duemilinove and have been VERY pleased. Many different config/s flashes on that one. doing many various things. ALL SUCCESSES!!!
Then I got a mini pro 5v. for a smaller footprint to finalize a project. once again PERFECT!!!
Now I wanted to slap up some wireless. And bam. nothing…
Its depressing to not even be able to find any posts that help either, nor tutorials that are REAL current.
I found one or two, but they havent helped. I walk-through them like a neanderthal and still nothing.
what gives?
coms are nice and matched with port speed, and all pc side seems fine.
Please help. Thanks
