New Windows version of OpenOCD r100 available
a new compiled Windows version is available here:
http://www.yagarto.de/howto/openocd/index.html
Here you will find a small tutorial and the link for the OpenOCD.
Best regards,
Michael
i have found a bug with rev100 on svn
It breaks gdb (insight).
line 706 of gdbserver.c needs changing to:
gdb_str_to_target(target, hex_buf, reg_packet);
The patch has been sent to Domonic.
Cheers
Spen
Hello Spen,
yes I know, we have found yesterday some more bugs.
This was corrected with a patch from Dominic.
But many thanks for the information.
Index: server/gdb_server.c
— server/gdb_server.c (revision 100)
+++ server/gdb_server.c (working copy)
@@ -491,7 +491,7 @@
if (str_len % 2)
  • ERROR(“BUG: gdb value with uneven number of characters encountered”);
  • ERROR(“BUG: gdb value with uneven number of characters encountered: %s”, str);
exit(-1);
@@ -703,7 +703,7 @@
hex_buf = buf_to_str(reg_list[reg_num]->value, reg_list[reg_num]->size, 16);
  • gdb_str_to_target(target, reg_packet, hex_buf);
  • gdb_str_to_target(target, hex_buf, reg_packet);
gdb_put_packet(connection, reg_packet, CEIL(reg_list[reg_num]->size, 8) * 2);
@@ -917,6 +917,7 @@
buffer = tmp;
+ retval = ERROR_OK;
  • switch (len)*
    _ /* handle sized writes */_
    @@ -985,6 +986,7 @@
  • return ERROR_SERVER_REMOTE_CLOSED;*
  • if( len ) {*
  • buffer = malloc(len);*
    The patch was not inlcuded in the SVN now.
    Best regards,
    Michael
