a new compiled Windows version is available here:
http://www.usbdip.de/en/openocd/index.html
Here you will find a small tutorial and the link for the OpenOCD.
Best regards,
Michael
Best regards,
Michael
Hallo
Die Version funktioniert bei mir leider gar nicht.
Openocd kann gestartet werden aber es kommt keine Telnet und keine
GDB Verbindung zu Stande.
Bei allen Vorversionen rc62 -rc80 klappt das.
Getestet auf mehreren PC´s und verschiedenen Betriebssystemen 2000 und
XP.
Martin
Hello Martin,
I have double check it here, and downloaded the version from my page
too. But I have NO problem here. Is it possible that you have change
some settings from your personal firewall if available?
Regards,
Michael
hello michael,
no i´ve never changed this. i test it on a new machine 3G Intel with 2 GB Ram in an out of a vmware - always the same.
then i install the rc80 - telnet and gdb works fine. but the other problems are still there.
the only thing i´ve never tested is an old slow pc - i must look for one.
maybe it is a timing problem ?
best regards
martin
excuse me for my prior posting in german
new test
i think in the rc82 the new params jtag_nsrst_delay etc. have changed.
with the prior version (80) i must use big values to get connection to the amontec key 100000 for example - that was the problem in the new version
i changed to 1000 then telenet and gdb connection works - but the other problems still remain. i remember dominic write´s that he would do such a change.
best regads
martin
Hello Martin,
the jtag_n[st]rst_delay commands where intended to specify a time in miliseconds, but r80 accidentially used microseconds. This is fixed in r82, and now matches the documentation (http://openfacts.berlios.de/index-en.ph … figuration).
As for your other problem:
Could you please send me (Dominic.Rath gmx.de):
the OpenOCD configuration file used
the GDB startup script (if any)
the GDB input/output
a log from OpenOCD (run with -d -l )
Regards,
Dominic
